Idling problems after ECU reset
Ok so here's how it goes. I recently cleaned my throttle body with tb cleaner recently and took it for a drive...damned thing was pretty responsive :D Anyway, I decided "what the hey, i'll reset the ecu while i'm at it" So i left it to reset with the negative dc'd for around 2 hours with the bonnet up. It cooled down, and i reconnected the negative terminal. It started fine, warmed up and...wtf?? It starts idling funny. It jumps up and down between 800rpm to 1.5k rpm...and it keeps doing this (i thought it was the ecu adjusting itself, but it just kept going). Sounds kinda like this "VROOOM vrum VROOOM vrum...". It wasn't doing this before reset the ecu, and it didn't do it before I cleaned up the TB either. Although i did get some TB cleaner on the outside of the TB sensor areas (but they're liquid tight right?), it shouldn't affect the idle correct?
I'm outta ideas. It was suggested to me that the dizzy needs to be adjusted but it hadn't been touched at all thus far and it ran perfectly fine.
Any ideas at all??
