[DIY]Ground cable, ghetto-bling-tightass make-your-own style
I know Wyn has done a grounding cable DIY before. But I want to go at it, ghetto tightass style!
Disclaimer: The following is provided as a GUIDE ONLY, and neither myself nor Ozhonda take any responsibility for the outcomes of someone else doing the following. You follow these steps at your own risk! If your car explodes or you lose your radio station presets which you forgot to write down beforehand because I did not tell you to, or in the worse case, lose your radio security codes it is not the fault of Ozhonda or me.:cool:
Aim: Everyone spends $120 or more for that capacitor grounding kit thing. Do they work? I have no idea. Do I want to spend $120? Maybe not (because I am tightass). Do I want to mess around with something ghetto? Hell yeah!
Required: Sockets that fit the bolts you want to take off. I used 10mm and 12mm, 4 gauge wire (why so thick? Because this is ghetto! Choose a colour you like), ring terminals/connectors for 4 gauge, negative terminal connector (optional), pliers, scissors, wire clippers (recommended), soldering iron & solder (optional), silicone spray (optional)
Steps:
1) Measure the length of cable that you require for a section. Let's start with the negative terminal to chassis since it is short and easy. Measure it and then mark it on the cable with a little snip.
2) This is the difficult part. Cutting it. Cutting 4 gauge wire using wire snippers is not easy..... Plus the cable is too thick to fit into the plier's wire cutter. Best would be to use a lock cutter. Had to use both hands to cut. Anyway, you know what a wire being cut looks like... right? Right?????
4) Ok, you've cut it somehow without accidentally snipping your pinky off (hey, it's the same thickness as a 4 gauge cable!). Now get your length of cable and your ring connector ready. Aren't they pretty?
http://img133.imageshack.us/img133/8918/parts5on.jpg
3) Take your wire and strip about 10mm off the end using your scissors. Why scissors? Because the wire is too thick to fit into the pliers or wiper stripper! After this step, I fit the sheath of the connector over the cable, just so I don't forget and only realise it after crimping the connector on. But hey, if it happens to you, then it's ok. Why? Because it is ghetto! Just put the sheath in through the other end of the cable. But that's a bitch to do because the sheath is so tight..... oh so tight......
http://img133.imageshack.us/img133/9...ipcable0fl.jpg
4) Now, this is an optional step but I recommend it. Soldering! It's fun to solder. Didn't you do this in your school's workshop/electronic classes? Except that you are not dealing with 1 strand of wire. You're dealing with a 4 gauge! So that puny soldering iron won't do. Time to break out the big guns!!!! If you don't have big soldering irons.... (well I didn't), then use a small butane soldering iron instead. Why do I solder? Because once you solder it, the tip is stiff, and when you crimp it the connector is less likely to fall off. Stiff tip, won't fall off. I am starting to like it already. http://www.acurazine.com/forums/images/smilies/wish.gif The unsoldered cable is soft and the connector fell off after I crimped it. Soft is not good. Why do you think the little blue pill is selling so well?
http://img157.imageshack.us/img157/1...ingiron5zd.jpg
5) Get the tip very hot, and then put solder to the cable and heat them up! Heat heat and more heat! Make sure the solder melts and soaks in between the strands of wires. Oh, and don't burn your fingers or clothes. Burning flesh smells like roasted squid. Yummy! Oh.. and it hurts too.
http://img133.imageshack.us/img133/9...rcable27sn.jpg
6) Let the hot tip cool down. Then take the connector, widen it a bit using pliers. Put the cable in and squeeze the bugger tight! Pay no attention to the ghetto scratches and the flaking gold plating.
http://img148.imageshack.us/img148/7...nnector0lw.jpg
7) I sprayed a bit of silicone lube onto the connector and exposed wire. Why? So that it slows down corrision. Well, at least I hope it will. Then pull the sheath over the ghetto part so that it is hidden and all you see is a professional job!
http://img148.imageshack.us/img148/9...edcable5du.jpg
8) Now, repeat for the other end if you need it for both ends. Once it is done, it's time to install it into your car! Now.... what stands out the most in my engine bay..... AH HA! That weak tiny cable from the negative terminal to the chassis. Look how dull and thin that 8 gauge cable is! Take it off!!! It''s connected to the chassis by a 10mm bolt.
http://img109.imageshack.us/img109/4...akcable3zn.jpg
9) Take the bling bling replacement and put it on. For the terminal I used, it accepts a 4 gauge cable without a connector. So just solder the end and put it in. Tighten down until you feel the pleasure... Then, take the other end and connect it to the chassis. Oh and watch the teensy weensy sparks too. Now... doesn't that look bling? Hmm, I should up the shine in photoshop....
http://img148.imageshack.us/img148/7...erminal2pv.jpg
10) What? Did I hear you ask if that's all??? Is that all? Is that all?? *Runs and prepares another cable* OOOoooh... let's ground that alternator. The alternator is fun, because there is an accessory belt nearby. If you have it the wrong angle, your nice grounding cable will be shredded by the belt. So make sure you plan your ground wire's location. I bent the connector so I could have the wire pointing towards the radiator. (ooooh, another heat source). There was one bolt on the alternator that seemed to hold the alternator to the block. So I just HAD to take it off! Hahhaa.. (no, the alternator did not drop off the block) It was a 12mm bolt btw. And a huge one at that. Of course the hole had to be too small for the shaft to fit in. In this case, there are no drugs to make the shaft smaller, so I used a dremel to widen the hole instead. Easy peasy. Look at how happy it looks now with a bolt through its hole.
http://img109.imageshack.us/img109/8...ernator9vg.jpg
11) And a very important thing to do is to make sure that the cable does not touch any hot surfaces. Even the metal on the radiator is mighty hot. So it is time to enlist the help of my leeeeetle friend... Mr. Cable Tie. Look at the pic! It's so stealthy that you can't spot the cable or Mr. Cable Tie!!! Well, they are there somewhere having fun. Just route the cable through and attach it to the same ground point on the chassis that you connected your negative terminal to. No point wasting extra cable if you are already using gooooold plated connectors (which are your only choice when working with 4 gauge cable because they are so bling).
http://img71.imageshack.us/img71/414...edcable7rl.jpg
Well, that's it for today. After this, I'm going to ground my head to my block (to make me a blockhead) and then connect that to the transmission case which then connects to the thigh bone... I mean negative terminal.
Benefits: None that I could tell, but wasn't that fun? http://www.acurazine.com/forums/imag...lies/drunk.gif
