found this set on eBay -- very cheap at U$35/pair, complete with all the other gizmos to get it up & running...
now, i am not too much of a DIY person... can some1 recommend a good fitter??
http://cgi.ebay.com/ebaymotors/03-04...mZ260007775100
I have researched these ebay fog lights for the CL9 and they are very hit and miss in terms of whether they will work at all. Some people report the harness does not wire up at all.
dude there is a guy in aus who sells the lights on ebay - just goto the aus ebay and search honda accord euro. Good luck
I bought these E-bay lights about 3 month ago... and yes nothing fits ! the switch is too big to fit in the hole provided in the car and the harness had to be rewired..... I couldnt be bothered trying to custom wire/fit the lights myself as it looked like too much rewiring and hacking into the cars electrical system, so I took the whole thing to an auto elec. Charged me $150 for complete installation.. and even got me a new switch that fits the euro... all in all Fog lights were $250 and installation was $150
Total approx $400 bucks....
good luck and hope this helps...
Where are u located? did ur auto electrician do a good job with the installation?Quote:
Originally Posted by pilotb777_300
Boleh,
I'm locate din melbourne. Auto elec did a really good job.... but if I had my time over again, I'd just get the lights from honda and get them to do it.. I think they charge about 600 bucks fitted. Thats an extra 150 but at least everything is from honda with honda original parts and they wont give you any crap with your warrenty if anything goes wrong with your electrical system. If you do wana go the Ebay route though and you live in melb, PM me and I'll give you the Auto elecs address.....
guys, im in need of new foglights. mine got stolen at the shops. lookn at probably aftermarket ones or sumthing that is good. i have no idea about foglights nor which brand i shud be lookin at. does any1 have any suggestions? i need them before the end of the week.
cheers cj.
im keen on these.
http://http://www.narva.com.au/ForwardLighting_4.html
wat use think? and has any1 heard of this brand before?
the website is not working for me.
I might be looking on getting 2006 model Euro foglight, exactly the same as the OEM ones. Is there any place beside Ebay I can look for?
I want OEM fogs for my '06. I wonder how hard it is to fit OEM fogs??
There is no difficult wiring required. The hardest part was getting the harness wired into the fuse box correctly. We had the complete instructions but it was a bit tricky at times. Getting the steering column cover off without damaging any clips was not easy on my car either.
I have no idea, but at least they were kind enuff for me to leave the wires hangin out still in tact. so now all I need is a pair of foglights bcos I don't need a relay or switch. I can just use the oem ones. ill see if I can get a picture up since the link aint workn.
I got 06 Euro. Is there any other option for fogs beside genuine Honda ones? I don't think those eBay ones fit 06 model bumper right?
Thanks.
someone on here is selling foglights for CL9...uz might be interested
http://www.ozhonda.com/forum/showthread.php?t=62715
it's better to get the OEM one i think.. it's precious and looks nice! :D
boleh, when you go home for holiday, go buy philips H1 bulbs.... cheaper and very bright also....
I have been considering fitting aftermarket spot/fog lights to my STD 05 Euro. However I was thinking along the lines of having them come on only when the headlights are on high beam, in which case a switch is not needed. I was planning to find the wire for the high beam supply and joining into it for a signal to a suitable sized relay. The main power to the relay and thus to the new lights coming from the battery via a fuse. That sounds simple or am I missing something?
should work.... fuse size must be correct, and I would prefer to have 2 fuse, one at the main power to relay then to spotlights, and another fuse at the high beam power to relay.
Attachment 4926
these are the foglights im talkin about. wat use think?
*bump
what is the difference between output wattage and consumption wattage? What are the specs of the stock fogs?
sorry to hijack, but do you know of any aftermarket foglights that use the same connector as the honda fogs? as i do not want to rewire the foggies in?
the 55w of the stock bulb, would that refer to output or consumption wattage?
just to bring this thread back up, im looking for a foglight kit to fit on my 06 stnd euro. does anyone know where i can get a kit from?
would this fit onto the 2006 euro? just wanna make sure.
http://cgi.ebay.com/ebaymotors/2003-...Q5fAccessories
Thinking about putting some foglights onto my std 2003 euro, don't know whether to go off ebay and then get installed by an auto electrician... looking at around $150ish for install i guees so approx $300 total.
Or head to Honda and see how much they want, i have head/read around the 600 mark fitted but don't quote me!
what do you think of these two set off ebay:
http://cgi.ebay.com.au/ws/eBayISAPI....STRK:MEWAX:VRI
hey guys, im new into CL9 scenes previously was R34 LoL. anyway i own a late 06 std model (post-facelift) and want to add foglights since canberra is waaaayyyy too foggy. i've searched many threads but noone strikes my q's perfectly. can someone guide me the right item since most of the sellers only sells pre-facelift foggies and where can i get the foggies cover?
thanks
