Just some quick pics I discovered on my computer of my boot making process. It may help people if they wish to do something similar.
I had a few requirements when making this floor:
1) It had to be simple and neat. I was sick of removing my sub and amp to fit my bike in the boot every weekend, so I had removed the sub altogether. In redoing the book I just wanted some bass to compliment the rest of the stereo, not hectic neon-flashing bass.
2) No permanent modifications were to be made to the car. No carpet cut, no holes drilled, no panels damaged. The car is still in very good condition, so I didn’t want to compromise that at all. Pieces are locked in like a puzzle. They do not budge unless you know in which order to remove things. Everything I have done is also reversible.
3) The spare was to be retained. The teg is a daily driver workhorse, and does some long distance driving too, so it needed to be practical and safe. The space saver spare is in there now but the full size spare MAY fit in there. I am yet to try.
Ok, pics…
1) Measuring up. I lined the boot floor with masking tape and foil, and then applied the fiberglass and resin. I think I laid two solid layers before removing it.
http://www.imagestation.com/picture/...c/eddc51dc.jpg
2) Mold removed. More layers added. I don’t remember how many, probably not enough though.
http://www.imagestation.com/picture/...c/eddc51d0.jpg
3) Baffle cut and sub mounted to check clearance. It’s a tight fit but I was happy to sacrifice quality for a bit more boot space. (It’s not the greatest sub anyway so I don’t mind).
http://www.imagestation.com/picture/...7/eddc51bf.jpg
4) Front bits cut out and bonded to seal box. Fibreglass outside and inside of the box. Resin was then poured around in the box to make sure of no holes. I mucked around with sound deadener inside the box and then stuffed it with Dacron. Sound deadener sheets were also put underneath the sub box. This minimized vibration greatly.
http://www.imagestation.com/picture/...5/eddc51b5.jpg
5) Top floor cover made. This was the hardest piece for me to make cause I’m not that great with the cutting. Was tricky to get the sub cutout spot on.
http://www.imagestation.com/picture/...2/eddc51ab.jpg
6) Other pieces cut and fitted. Amp sits upside down bottom left. No overheating problems yet.
http://www.imagestation.com/picture/...6/eddc51a4.jpg
7) Grille shape finalized and the bit the grille fits into was shaped. Nice smooth curves. I tried many different shapes and was happiest with this.
http://www.imagestation.com/picture/...6/eddc519e.jpg
8) Almost done. I need to still decide on what material I am going to fill the sub area with. I was thinking of finding some stock material off the seats of something to integrate the install a bit better.
http://www.imagestation.com/picture/...f/eddc519a.jpg
http://members.optusnet.com.au/~akarayiannis/Boot.JPG
This weekend if I have time I will remove everything and take better pics of the hidden stuff. I’ve been meaning to clean up stuff under there. I have also begun redoing the rear panels so that the insides of the amp are visible, and making one panel to go over the spare and rhs bit.
This could have been done differently, and most assuredly better, but I’m pretty happy with how it has turned out. Materials would have cost me $100-$150 at the most. Time is the hardest thing to find, as I have very little of it. Still, was good fun and suits my needs perfectly.
Newly resprayed bumper too!!! I need to get better pics!
http://www.imagestation.com/picture/...9/eddc2c20.jpg
