Just wondering how would i take the steering wheel off? its starting to make a squeek noise and i want to get rid of it
assuming it's an oem non-srs steering wheel..
pry the honda emblem off..
and there'll be a bolt there.. i believe it's size 20 ? or somewhere around there..
grab a ratchet, socket, extension.. and undo the bolt..
you should be able to take the wheel off now..
just a warning though..
i've read that it's better to undo the bolt.. but leave it on near the end, so when you're pulling the steering wheel off, it won't hit you in the face..
but this never happened to me.. so good luck :thumbsup:
dont del sols have air bag ?
2nd gen (96+) delsols do..Quote:
Originally Posted by EG5[KRT]
1st gen (92-95) don't..
Hey Man,
Yours is a 93 model so is a not Air Bag wheel?
If so it is pretty easy. From memory as it was a while since I took it of my Delsol, the front center panel just pulls off. After that you can access the nut that will disconnet the wheel from the column. There maybe a wire to disconnect the horn.
Correct ta mungo dude!Quote:
Originally Posted by tRipitaka
they didnt have an airbag in the 92 "delsol", but newer ones did, not sure when they started exactly i think it was 94
edit: damn too slow
Yeah i think they added them in around about 93/94 ish.
I think it would be similiar to either an eg civic, ek civic or a dc2 integra.
exactly the same as the non-srs eg civic.. exactly the same wheel too..Quote:
Originally Posted by JasonGilholme
fairly different from the ek civic or dc2
funny you guyz say that because the center doesnt come off, its a honda symbol, but it doesnt come off, hmm air bag? i dont think it does,
i know this is going to haunt me lol
trust me.. use a flathead screwdriver and pry it off..Quote:
Originally Posted by crxdude
it'll come off with a little persistance and a few beeps of the horn
You should be able to tell if your car has an air bag just by looking at it.
I think there are some stickers on the underside of the bonnet regarding the SRS system so if those stickers are there you should have an airbag.
Theres probably a better way to check tho.
SRS
http://images.carsales.com.au/private/1625575.jpg
NON-SRS
http://images.carsales.com.au/private/1317854.jpg
if you have a 93 delsol, you have no airbags..
96+ have airbags.
...i knew there was a better way... :P
ok its the 2nd pic, non srs
jesus you guys are good.
I never was a honda fan but when i brought this b16a2 del sol i was like jesus christ the power is awsome!
Dont you just love the vtec sound in a car park :)
ok now umm would u guys know how to fix these squeeq noise? wd40?
ALL FIXED! a bit of wd40 did the job, now the horn dont work, i might check it out later, but thats all for your help :)
Thanks again
SRS was introduced in 1996
