Does neone knwo how to change or have a DIY thread for chanign gearbox oil?
one coming soon.....hold ur horses luv ;)
hahahaha pls do so before i run out :D
easy... just undo drain bolt on bottom... do up bolt on bottom.... open filler plug on side.... fill up with engine oil (yes engine oil most hondas use this in boxes) wait till it pours out the side.... close plug and go for a spin :)
:shock: OMG!! :!:Quote:
Originally Posted by daboss";p="111604
true, true....
GL4
check the owners manual and you will see :)
Believe it or not that is what the service techs at Honda do.Quote:
Originally Posted by SPEEDCORE";p="111711
I'm shocked...... don't understand why honda makes a separate MTF then? :?
What about issues with viscosity? Any?
Which dodgy dealership is this? Let us know. :?Quote:
Originally Posted by vti-2";p="111955
all dealerships will now sell MTF. about 7 years ago FEO was da way to go. Mazda uses ATF in [acronym:2a2f433de9="Front Wheel Drive"]FWD[/acronym:2a2f433de9] MT for 323 ect
you actually have to put shit engine oil in the box to be even more precise...
similar to what you put in motorbikes as you dont want all the additives, friction modifiers etc.... friction modifiers do yucky things for syncro's...
I'll stick to MTF!
yeah me too....
