this is a question for all u DC2 type R owners.... wats are u reving at when doing 110km/h
cheers
cheers
~3500 - 4000 from memory
at which gear? 5th?
in fifth from memory its a touch under 4k rpm, but that might be 120kph
I think around 4K rpm from memory (bit under)
5th gear, roughly 3500.
3500-3800 from what ive heard
is the AUDM ITR tranny (gear ratio) same as USDM ITR?
3500 at 100km/h, a touch under 4000 at 110km/h.
around 3500-4000
thanks for the reply guys....
Yeh, im talking abt 5th gear at 110
Just needed to know as my speedo is abit out of wack
shouldbe around 3800rpm
mine , 5th gear 100k, rpm is 4000, 110k/h ,rpm is like somewhere between 4000 and 4300
5th gear at 110 is 4000 rpm...
5th gear - 3700rpm
ah ok... i might get it check out next time on the dyno'ed...thats proabably the most accurate way
thanks for ya input
U guys stop speeding, speeding is bad mmmmkay!
VTIR @ 110 = 3.5 rpm from memory.
Type R are always 500 rpm higher than VTIR.
btw to confuse things, our speedos are not accurate hahah. use a gps and you will see.
yeh around 3500 to 3700 ! =) from memory
no 2 speedos are 100% the same. Nor accurate lol as said.
Also to make matters worse , those with conversions will run even less accuracy.
Also different tyre/rim size combos will put your speedo off more.
DC2 is 3400
DC2R is 3800
around 3850rpm at 110 km/hr
My DC2R is around 3600-3800 Rpm @110km/hr. It really depends on the set up in the car.
Factory DC2R drivetrain will be right on 120km/h @ 4000RPM
Without the floormats this can be quite loud :)
3750 rpm on mine with new 195/55 R15 tyres at 36psi
3400rpm on mine with almost bold A048 195/50 R15 and stock rims
As described in this thread , No DC2R with different mods ( wheels / tyre profiles / weight etc) will put the exact same RPM per 100km/h.
Too many variables put the VSS out of whack.
True indication of your speeds accuracy - drive next to a 100% stock DC2R and judge your speedo compared to it.
Closed
