Speedo dropping out
after servicing my crx yesterday, i took him for a spin and my speedo dropped out. i noticed that it comes back in around 40k's, then drops out at 60. does anyone know what the problem could be/how i could fix it?
im thinking it may be a fuse or i've knocked something when i serviced it
make sure the VSS connector is plugged in firmly and if it is, it is more than likely the VSS failing, very comon problem.
the what now hahahahahahaha
where is this VSS connector residing in my engine bay?
gen2 or 3?
B or D?
D16A8 & B16A gen1,VSS is in back of cluster with cable driven connection to g/box.
B16,18 hydro box,VSS on top of g/box with wire connection to cluster,look for elec connector on top of g/box below dizzy.
gen 2 d16a8
so its a connector to the gearbox? is it in the engine bay or underneath?
If its the VSS thats faulty its on the top of the box. Probably have to take the intake arm out to work with it properly.
hmm... if it is on top, then i may have bumped itputting my intake pipe back on
Maybe. Sounds like its just a bit loose and the connector isn't in fully.
Dunno what other damage you could do to it. but i have heard of alot of people having to replace them.
hahahaha you'd be surprised at what damage i could do hahahahaahaha
i'll check it when i get home. i hope its not broken.... coz im not keen on replacing it atm
You should be able to pick it up cheap from a wrecker. They won't know what it is.
if you have an ED9 AUDM D16A8 CRX, its cable driven and the cable could have poped out from the VSS drive on the gearbox, you just have to push it back in.
after reading your post about the intake sounds like you pulled on the cable or someting like that.
for those of us that don't know what the VSS looks like.....is there any chance someone has pic or pinpoint a location for me to try and find it
i've done some searching through the online manuals i have, but none show this part
thanks for the help from those who have posted already
its probably not the VSS as that is in the cluster and driven by the cable
look behind the throttle body down at the gearbox, you will see the speed cable coming from the firewall to the gearbox, what you have to do is push it in more into the speedo drive assy. there is a clip in there that is ment to snap the cable in place and hold it there, it can be a major bitch to get it in.
if it take me to long to get it in, I jack the front of the car up, support it on jack stands, let the engine idle in gear so the front wheels are rotating and push down on the vss cable so it finds its way into the notch. bit crude but it works rather quickly.
good luck with it
cheers mate, i'll give that a whirl when i get home
i'll thank you in advance as i wont be on for the next 2 weeks!
