what mods need to be done to achieve this rev limiter sound when it hits red line.
er.... just keep on revving your car all the way until you hear it.
Ummm try running a straight pipe off your headers..:p
Seriously though what type of sound are you after??
http://www.youtube.com/watch?v=Yaxw5ZPXBrk
listen to the white eg
i just told you how to do it.
thats not what i meant,..
ever see a cluster needle (rpm) flick back and fourth once it hits red line.. thats the sound im talking about.. it doesnt do that normally does it? cause i tried..
yes, you rev it, and keep on revving it past the redline, and you'll hit the rev limitor.
Yeh it does, your just not revving it enough....
^Exactly.Any loud exhaust and bounce it off the limiter...simple.
if you have disabled the rev limitor and you'll valve bounce, similar sound, BUT, causeas damage.
lol
You mean like this right? :http://www.youtube.com/watch?v=0_CmhEL49mY&NR
ahahaha ross u hater leave the kid alone
lol, hit the limiter 3 out of 4 shifts...thats BAD form!
hmm on point tho, i think what he may have meant was the 'quick' flicker as opposed to the ordinary limiter, which is quite slow to 'bounce'..(?)
Answer is any decent aftermarket computer will have that speed cut-out as standard..
ive revved my stock EG to 9.5K and it was ok...
just ***in loud... and not healthy...
the toyota echo bounces like crazy in 1st, its the work car, thats why i treid
IM hitting my KPRO Hondata ECU launch controller when i launch the car.
honestly tho, y wood u want to? the limiter cuts in a fair way into red line so the engines stopped making power in that gear, its jus making noise and putting unecessary stress on the engine. i saw a guy in a soarer bouncing it off the limiter driving down the street once and i jus thought 'was a toss, thats poinless'.
^^^ sounds cool.
you can just get aftermarket ECU and drop the redline for that sound and being safe
na i think he means bouncing of the rev limiter...
lak sooo..
http://www.youtube.com/watch?v=40wKibRg40o
even the kid can doit!!! lakk sooo
http://www.youtube.com/watch?v=kNiyx19QIhA
so what actually happens to ur car when u put ur foot down and leave it there?
same thing that happens in any gran turismo game, it bounces of the limiter.
Also, the higher gear you in, the slower the bounce as ur engine cant pick up the 500 or so rpm it drops as quick as u lack tourqe in higher gears.
ie, N or 1st bounces quickly
5th bounce very slow
Here a little kid doing it in neutral:
