anyone got an idea of how to adjust your coilovers and have them balance? making sure each side is the same height etc?..... any insight would be great...
cheers.
cheers.
For Koni Yellows....
http://img72.photobucket.com/albums/...clip_slots.jpg
See the grooves??
See the yellow circlip??
Move the circlip up and own to adjust height, and slip the springs seat over the top, like this
http://img72.photobucket.com/albums/..._seat_used.jpg
Thats how you adjust the height... then stick it all back together like this
http://img72.photobucket.com/albums/...k/DSCF1162.jpg
Notice how the spring sits lower than the standard one.. look closely, its not a lot (10m)
Hope that helps answer it for someone... Coilovers are basically the same (some are, some aren;t)
thanks McChook, thats seems understandable in a koni point of view, since there are grooves, and basically you just slot the piece you want to adjust into one of the grooves.
how about something like this
http://firesport.ipspace.com/item_images/8948.jpg
or
http://firesport.ipspace.com/item_images/8946.jpg
seems like you screw the plate up and down for this one?
Those are easy. Just use C-Spanners.
best way to do it, is jack up the car and wind them all the way down, then, count the turns as you wind them up again
ok cool, thanks mate :D
How accurate are your turns?
I guess it depends on how pedantic you are as well. For me, if you have gone to the extra expense of coil-overs, you want to have them set-up 100% spot-on so that you can make the most of them.
A full-on setup would include corner-weight balancing where scales are placed under each individual tyre. You can then adjust heights to get precise weight proprtions, etc, depending on how you want it setup.
Myself and my father do this for petty cash actually. We have a set of cornerweight scales.. If anyone would like to hire us (Colin Osbourne is a customer), PM me.Quote:
Originally Posted by Jus-10
I may just take you up on that when mine arrive.
What car you got and what brand coiloversQuote:
Jazz - Tein Super Wagons.
and where do you get these scales from? or is it a workshop tool? :P
They are about $2500 for a good set....Quote:
Originally Posted by A'PEXi
I think www.performancewholesale.com sells the longacre ones
What a shit diy
