i was jst wondering if anyone else had the same problem, everytime when i take off in 1st gear my integra will whistle for a couple of seconds, i dont think its the air intake, my car is completely stock does any1 know what this could be??
Wheres the noise coming from exactly?
as above, where is the noise coming from exactly?
if you have an aftermarket intake, it could be that. In most cases it usually is, however you'll need to be a bit more specific with details for anyone on here to be able to help you find out where or why its happening.
the sound is coming from somewere in the engine bay, when i even out the clutch with the accelerator that when it whistles, one the clutch is completely out it wont whistle
Sounds like its clutch noise when the clutch is engaged.
would that be a serious problem?
whistling is using the air intake
so does it only happens on first gear?
could be bearings in the gearbox..
have you got a stereo?
cause if u got amps etc.
bad connections get whistles.
nah theres no system nothing the car is factory standart no cold air intake nothing, yea and it only does it in first gear when i even out the clutch, how can the bearings in the gearbox be making a whistle?
lol my dc2 sounds like it has a super-charger when i have the A/C on
Ditto :P
are you sure it's not the bearing in your gearbox gone?
How olds your clutch? if its worn it could be slipping on its rivets
lol, how can it be fixxed
To fix it would mean a new clutch plus the labour involved in doing it.
Just get it checked out by a mechanic first before you go out and start blowing money away.
nah the clutch is fine, its like new does not slip at all, im worried about the bearings in my gear box dont know anything about them
I have a friend with a dc2 vtir and his spigot bearing on his fly wheel failed causing a squeaking sound. As for the gear box if the bearings are worn it would sound as if the gears are crunching or grinding under load
