Your D15b/16z6/y8 All D Series Dyno Results
hey people, I noticed there is a b series results page, but I want to see some serious d series dyno results page, I know when I complete my engine (rebuild with 1.6 high compression 11:5cr and a good tune (crome) ill be posting up my dyno results cause there are allot of d series engines from the breeze up to the sohc vtec models., and now that parts are available to work these engines pretty easily, we should all post our d series dyno/track quarter mile results here., p.s. moderators make sticky for future comparing.
ppl don't forget to post your mods as well, like my Honda city 92 vtec(civic engine, crx p29 zc pistons, d15b vtec head, d16y8 block, compression to 11.5, 1.5 mm head gasket.,adjustable cam gear, extractors, throttle body,crome program datalogger modified ecu, 2in exhaust all the way with high flow cat/muffler. etc, when I get it running again, was previously running 15 cr, almost blew the engine, pinging crazy (detonation).
I’m expecting anywhere between 115kw at the engine to 130kw. Factory engine makes 100kw with factory airfilter/exhaust/ecu/9.1cr so I should easily climb the latter.
