i have tried several times to get this right without luck sump gasket keeps leaking.....Installing new baffled sump with stud kit
I torqued the the sump down to the correct torque setting (96 inch pounds b18c )but it seems 4mm off sump gasket squishes out the side
Is this normal
it seems to leak from the crank pulley end the rest is ok
What is the secret to getting the gasket to seal correctly
i have tried with gasket goo and with out and I am using oem honda gasket
