TEIN SS Installed with Whiteline Rear Sway Bar
What can I say but :
http://img299.imageshack.us/img299/4331/sideqtrek9.jpg
Mini Review: Tein Installed and RSB in. No camber or strut bar yet. New Tyres BFG G-Force
Setup:
Ok. I asked to have the car lowered 40mm at front and 35mm rear but I think its a lot lower than that. Its too low at the front. Ill raise it 10mm. It scraps on the back of an ants arse.
Theres 3 degrees of rear camber which is ok for now. Camber kit next week.
I have 0 toe on front and 1mm positive each rear for a total of 2mm positive. It tracks VERY well. Its very stable, way better than stock and doesnt pull. Even with the 3 degrees camber.
Brief Opinion Day one:
Its handles almost completely flat. It has an abundance of front grip, giving a new found confidence through corners at speed. The "doughyness" through roundabouts when pressed has been replaced with a solid connection with the road, giving you the confidence to adjust your position as speed when needed with no unsettling. Its safer than stock I believe because you can react and be connected to a result immediately on the road. Basically it "feels"like you can take corners safely at double the normal speed. i would never attempt that on a public road though. Another point that i didnt expect: the VSA is kicking in MUCH later than before. Yes I have new tyres but the VSA is seemily not interested until the very very severe limit. Before it would engage willy nilly.
The car feels a lot more solid because its not moving around at all.
The ride is excellent when set at the 8/8 shock setting and handles bumps very well. That being said I wouldnt be crashing over large potholes in a hurry.
Overall :
Im very pleased with the result. It has exceeded my high personal expectations. Handling very good, ride excellent. Look = great. Ive got that semi touring car look i was after. No need for a bodykit.
Next:
M3 lip spoiler and front strut install -
PS: Yes some lame b'stard stole my centre cap. Trying to get a new one from speedy is not easy...
