Hey,
i read alot about engine earthing kits, found one that claims up to 3kw gain at the wheels, $260... anyway, they look ugly as hell, and are a major rip off.
I decided to make my own custom kit. I don't believe I'll get much if any power gain, but im expecting smoother idling, better accelaration under load, and better sound quality from sound system. First i decided to measure the idling voltage on the battery (using a very accurate multimeter!), this averaged at 14.24volts. then i checked the voltage on the engine block, reading an average of 14.21volts. so a slight drop in voltage there, which isnt suprising considering theres only one 4G cable for the entire electrical system screwed into 1mm steel.
I then made a short 2G cable, that runs directly from the negative terminal and bolts onto the engine block, from there a ran a 8G cable directly up to the valve seat cover. Started the engine up again and tested the voltage. Suprisingly, there was a fairly big difference. The battery voltage was now 14.43volts and the voltage accross the engine was exactly the same! no loss at all, thats what i wanted. but the fact the voltage now increased shows the alternater must be running better off a more efficient engine. i have doubts to whether theres going to be any power difference, but for a $15 upgrade, you cant go wrong! who knows, it might save me some petrol money :D
