Originally Posted by
bennjamin
Opinions is what breeds INCORRECT information. If someone views "your opinion" and takes it as "right" - they tell someone else the same info or worse yet do the wrong thing. You get neg rep for giving out wrong info plain and simple.
CV joint boots NEED to be replaced as soon as you can.
You CAN drive around abit with them torn (say enough until you can afford time to get them fixed etc) but you should never just leave them exposed as they will deteriorate quickly.
BTW shebangs , change the rack boots too as they serve the same purpose ( to keep lube in and dirt out)
