Originally Posted by
claymore
All modern radial tires take a "set" in their cords. That simply means they have been run in one direction and the cords conform or bend to the forces put on them and will remain "bent" in that direction of travel. If you then turn the tires around and run them in the other direction there is a increased chance of the cords resisting movement in the "wrong" direction and overheating or separating due to the excessive heat created by the resistance.
So that simply means that directional or not you SHOULD put them back on GOING IN THE SAME DIRECTION OF TRAVEL.
So if you are cheap front to back and back to front SAME SIDE ONLY. Or send the money and have the tires dismounted from the rims and x rotated then put back on the rims and balanced going in the same direction but with the inside now out.
