Originally Posted by EGB16A
I've done heaps of research on this and done a little work myself...
Vinyl dye works great, i used it on the vinyl pieces in the back of my EG hatch and it looks almost like oem. Clear coat will make it look stupid shiney, and cheap IMO. You'll only need to use that primer under coat shit if your going to use paint, which i personaly wouldn't do. If the vinyl dye is applied properly, it will last ages...
Integra dash will fit, however, you'll have to modify the wiring for stuff like the air-con and afew other bits. The cluster should fit fine.
Once the dash is installed, there are gaps on either side of the dash about 2cm or so from memory. You'll also have to change the mold on your door trims to accomadate the curve of the dash, it sticks out further by another 3cm or so.
integra door trims will NOT fit on the civic, the door is shorter and higher on the civic (or the other way round, can't remember)
Also, the a slight modification to the dash mounts will be needed, otherwise your dash won't sit exactly straight.
hope that helps?
cheers
Lloyd
