Originally Posted by
DLO01
Wheres your turbo oil feed? from the back of the block? Best place to feed oil to your turbo is via a sandwich plate under your filter. But thats another subject.
What is your turbo? line sizes? Have you a restrictor? Restrictor in turbo. If you have not got a restrictive path, the oil will take the easiest route, that being through the turbo straight to your sump. And your engine will not be getting much oil. If your not hearing Vtec then its quite possible your pressure is not enough and you could be risking your motor.
Of course Vtec is going to sound less. NA you have an arm and a filter on the end. Vtec induction noise ftw.
Boosting you have piping, piping, more piping, intercooler, piping, turbo, piping, filter. Of course its not going to sound as loud. You can still hear the crossover, its just less of an induction noise and more of an engine noise.
Oh yeh, and don't boost her untunned. ping ping boom. :p
