I often put my car back into neutral when I'm going downhill, or when I'm a bit excessive over the speed limit; rather than breaking, I put it into neutral to slow down (most often done on freeways doing 100km/h+).
Bad habit?
Bad habit?
Meh, I do it all the time. Wear out your pads quicker, but pads are cheaper than petrol.
firstly, putting into neutral doesn't necessarily mean you're saving more fuel than in gear.
secondly, its dangerous to put in neutral when you're going downhill, over speed limit and so on. its slower to stop the car when something happens suddenly in front of you. ie. less control of your car
so to me, its a bad habbit.
bah, when will people learn.
yes, its a bad habit.
it uses MORE fuel than leaving your car in gear.
people have this misconception that higher revs = more fuel. its just not correct - the load is what determines the amount of fuel going in. when in gear and decelerating, the injectors shut off as the momentum of the car keeps the engine turning whilst the clutch is engaged.
when the clutch is out, or the gearbox is in neutral, the car has to be kept at idle to avoid stalling, which obviously uses fuel.
as others have said, it also means you have less control. what about if you needed to accelerate suddenly?
its a big no no
Popping it into neutral is similar to clutching in during a corner....you just dont do it!
If anything was to happen which required you to slow or accelerate suddenly, you'd be screwed!
it is also illegal - "not have proper control of vehicle"
even the law said, when you are stopping either on a red light or not. its best to put into first gear. just in case someone hit you from the back and doesn't let your car roll into the middle of the street.
that why during your manual Ps you fail if you pop it in neutral
true that!
its common sense. Leave your car in GEAR while driving in ALL situations.
been covered before. exact people in this thread giving warnings are the same as the ones before.. heed them...
to the original thread poster....
if an animal or pedestrian suddenly jumps on the road and you swerve to avoid them while in nuetral.... post back here and tell us what happened if you live to tell the tale...
all of you who do it are fools, i pity you.. you should go back to yr7 and study some basic physics.. specifically inertia.
L's book does not equal LAW...
blk shadow - if you wanna refer to the "law said something" - use the Australian Road Rules:
http://www.rta.nsw.gov.au/rulesregul...ds/pts1-21.pdf
damn, beat me to it...i remember u tellin me this when i borrowed ur old car and driving to ur work...
anywayz, avoiding an unsuspected obstacle can have horrendous consequences due to the pendulum effect a car has during sharp, jolty cornering when in neutral...
being in gear dictates ur car's transfer of weight when in gear...specially in emergency circumstances where ur reactions would be to swerve around an obstacle...apart from the car's weight transferring from left to right, u've also got the gear moving the weight to move laterally...which dampens the shift of weight...
in laymans terms...
grab a rectangle block, and imagine that its the car...now, try to tip it on its side...and compare that to the amount of effort it takes to tip it forward...
the point of that was not to prove cars will tip forward, but the comparison of amount of force it takes to move the car side to side, compared to the force to move it back n forth...
that one line is well put.. just cbf explaining it again but you worded it nicely.
remember that downhill twards the roundabout in castle hill towards pennat hills... i provoked it on wet road in my mazda ages ago just to see how severe the effect was... and it was dangerous... a damn stupid experiment at that...
Thanks guys. You've possibly saved a fellow man's life :)
AAMI is doing a great job with giving people incentives as discount on insurance if they take a defensive driving course...a friend of mine (under 25) did it a few months back and gets like 15% off...
they teach these techniques on that course plus a lot more simple things that wouldn't really come to mind when ur behind the wheel...
e.g. he was tellin me about debris in the car causes just as much, or aybe more damage during a car crash than the crash itself...a baby was killed, even though it was strapped to an approved capsule, by a mobile phone sitting on the dash and went flying hitting the toddler on the head...
guys, girls, everyone,
for more discussion and advice on road safety - i feel this site is EXCELLENT:
http://www.crashprevention.com.au/index.html
even just the basics - are YOU a safe driver?
see here: http://www.crashprevention.com.au/sa...fe_driver.html
i thought being in neutral doesnt slow you down, doesnt it cause the car to roll more freely in comparison to being in gear? [refering to first post]
im probably wrong..
=p
i would hate for the engine to break at 100km/h!
I think he meant engine braking. Or were you kidding around? :P
i leave my car in neutral and run around fred flintstone style
for most modern cars, coasting in neutral uses more fuel since the engine needs fuel to keep it from stalling, as if its in gear there's rolling momentum to keep the engine running. Also try braking hard whilst in gear and in neutral, you'll notice the in a car with no ABS, braking in neutral will cause the wheels to lock up much faster compared when you have it in gear.. so yeah, it is a bad habit and its unsafe
the proper answer to the fuel question on a Honda forum is:
the Honda PGM-FI system that controls the engine shuts off the fuel injectors if the throttle is closed and the car is in motion and the RPM is about ~1200rpm (rpm differs for different models)
therefore, as D4rk4n63l says, the engine will use more fuel if it is idling compared to if it is coasting...
are you guys sure? (serious question)
coz voltage readings of AFM/MAP/O2 are VERY low on idle with injector duty cycles around ~%5.. ie Neutral....
Or is what tinkerbell said above a specific Honda 'feature'?
with that ~1200rpm thing, does it happen around there or below that?
when injectors are shut off - injector pulse width = 0
when injectors firing at idle - injector pulse with > 0
as above,
the cut off rpm is around 1200 to 1500 rpm.
it determined by rpm, tp, and map inputs to the ECU
If you some what, like it being in neutral, use the clutch instead. :)
Easyer to let go of the clutch rather than put it in gear.
Hmm since the topic of leaving it in N etc is up I might ask a noob Q.
Some people mentioned that leaving the car in N will result in the car consuming fuel to prevent it from stalling. However other people claim that leaving the clutch in will wear out your throwout bearing prematurely.
Scenario: You sit at the turning lights and the first few cars manage to get the green but u being the unlucky one catches the red again so this means another 3 mins wait at the lights until your turn.
In this case would you pull your handbrake up and leave it in N and wait until the light goes green
or
Keep your foot on the brake, foot depressing the clutch pedal whilst in 1st gear? As we all know that we've been taught to always keep it in first by our instructors.
What's the best thing to do?
I leave mine N handbrake on, I was taught to take corners at 5km by my instructor, do I still do it? No
but if you are hit from behind, how are you going to be certain your foot will stay on the brake?
maybe use both? super caution!
Or, we could make up signs for the back of our cars, "Please dont hit me, im still deciding whether to use my handbrake or brake."
Would it work?
i think the law says to keep it in gear, clutch in, because they assume that if u are hit from the back u will just drop ur foot off the clutch, staling the car, so it will move much less than it would if u got hit from behind and was pressing the brake pedal with the gearbox in neutral
It's easier to lift off if you need to. Just like cruising in neutral is not good in case you need to accelerate to avoid an accident, sitting with the parking brake means you take more time to release your brakes and accelerate off. Of course, you can always accelerate without releasing the parking brake, but I prefer not to.
Could you show me where it says that I have to keep it in gear and clutch in? I downloaded the whole file on my slow internet connection and went through over 400 pages, but I can't find it: http://www.rta.nsw.gov.au/rulesregul...ds/pts1-21.pdf
im not actually sure, thats y i didnt quote any official documents
i just remember something vaguely from my L days
but meh, i dont keep it in gear anyway, lol
but if ther was such a law, the reason would be as i said in the previous post
ooh, check the vicroads rules aaron, im melb remember
but yeh, its offtopic, but interested nevertheless
http://www.vicroads.vic.gov.au/Home/...ByVicRoads.htm
Checked it and can't find it as well.
Also offtopic, NSW road rules also includes hook turns now. So there is no excuse to not knowing how to do hook turns in Vic.
lol, hook turns are cool, u shoud see the look on most peoples faces wen i pull a hook turn in the city, they ask me, wth u doin, nubs
I thought you were only allowed to do hook turns in an intersection with a "hook turn only" sign?
yeh, isnt that how it works?
is ther no hook turn sign were cris is doing hook turns? lol
I have left the habit of coasting downhill on neutral, but I still can't get out of the habit of putting it in neutral when I slow towards the red light.
It seems unanimous that most beleive you save petrol by keeping it in gear, but somehow, trip computer seems to disagree. I travel the same route every day. Decided to leave it in gear where I normally wouldn't. After a couple days my fuel consuption is 9.3 up from 7.8.
Also regarding hand brake/foot break, I'm pretty sure I was taught hand brake start for a reason.
your trip computer is wrong. OKOK unless your car defies the laws of physics
And also, if you'd pay attention to your instructor, you use handbrake when your up a hill, otherwise footbrake that sh*t
thats because the trip computer doesn't take into account injector duty cycle. it only takes into account RPM and pays no notice to load on the engine.
You'll find taht you'll still get the same amount of k's out of a tank no matter which way you do it (unless you drive down hill for 400km's striahg lol).
Either way, fuel consumption should be the last thing on your mind. i'd be more concerned about vehicle control. :thumbsup:
there isnt one about when being stationary.
as said previously its just a guidline in the learners book. ie. good practice to do so.
yeah i remember as learner. you always gotta clutch in, never put in neutral at lights.
When I stop at lights for a while I put it into neutral with my foot on the brakes.
I thought that's what you're supposed to do?
Clutch in while stationary? Sore calf ftw.
still better to keep it in gear/change down gears as you approach the light. Gives you more control and its also easier on your brakes.
easier on brakes but worse for clutch/gearbox...???
hmmm, i know which one is cheaper to replace...
^^ :thumbsup::thumbsup:
What I usually do is put it down a gear and apply the brakes also, best of both worlds i guess!
