Problem
Hey guys im a owner of Ek1 Honda civic Hatch...
you guys mite know that honda civic keys come wid a chip in it to start ur car... i just wanna no if any of you guys have done the same thing like me losing that bit
and no i dont have a spare... is there a way to start my car with out forking out 850 bucks
I think he's referring to the immobiliser?
my mate did the same thing. he forked out the cash. i say, goto a alarm shop and get something aftermarket install.. im sure they can override the stocky and give u something nice for that kind of money.
????? you mean the key itself????
order a key from honda
cost like 30 or sumtin...cuz did it for his s2000
the immboliser is in the key. honda will charge u ~800 to get everything recoded.
someone asked pretty much the exact same question not too long ago...
check out these threads
http://www.ozhonda.com/forum/showthr...ht=immobiliser
uh, they might be confusing, but has sum good info for ya :D
have you lost all your keys. or just 1 black and 1 red ket lost leaving you with 1 black key.
if you lost red key and have only 1 black key go to locksmith, I hear they can copy your existing key RFID.
if you lost all keys, hold your ancles. quiz you Honda dealer as you can get a new imobiliser unit with a uncut red key and two black keys. then get it cut to the code of your lock or the tab which you probably dont have either.
weq, you just cant bypass the Honda imobiliser, its more tricky than that, you must remove a modual from the ecu and jumper a few things and add some bits then you might still get a code or a dead ecu. although the yanks say they now how to do it. its not a walk in the park.
good luck
fair enough, didnt know that..
Good reason for OBD1 conversion and Hondata :D
If the ECU is a P3X or P3Y I can help you out by removing the immo all together.
Let me know of you want to go down this route.
mines obd2b.. does it have inbuilt immo ?
