sound deadening wheel arches
This was covered previously but this a better pictured guide of using brush on deadener. The other DIY is spray on, which is more costly and less effective as the brush on gear as it is a better compound and a thicker amounts can be put on.
Aim: To quieten tyre noise
Required:
Wax and grease remover
Brush on sound deadener (4L drum is heaps enough to do all 4 wheels)
paint brush
srcubbing brush
plenty of rags
jack and car stands
Steps:
jack the car up. make sure the weight is held up by stands not the jack.
remove wheel.
http://memimage.cardomain.net/member...41_49_full.jpg
there will be years of dirt and tar etc built up one the arch. this will all need to be cleaned off with a good scrub and wax and grease remover.
http://memimage.cardomain.net/member...41_50_full.jpg
once the bulk crap is of and you see the paint give the paint a wipe with a clean rag and wax an grease remover to remove all the residue.
http://memimage.cardomain.net/member...41_51_full.jpg
then cover your brakes and suspension with rags to stop any drips from falling on them and paint away. start with a thin coat and build it up as thick as possible. a layer 3-4mm is easily obtained.
http://memimage.cardomain.net/member...41_52_full.jpg
do the areas of the arch that are between you and the cabin. no use deadening the engine firewall etc.
Other comments:
This difference was instantly noticeable! almost no tyre noise!
if you were to use the entire 4l drum of deadener that would only be about 4-5kgs of weight. the whole drum isn't needed to do the car tho. i only used 3/4of the tin to do a very heavy coat on the rear and 2 heavy coats on the front. for hardcore save weighters not for you but those in bigger cars or those wanting a quiter ride but don't mind a extra 2-3kgs definately worth the 40 bucks for the deadener!
cost effectively deadening
it is possible to deaden quite effectively on a tight budget. the 4L drum was bought from super cheap. this alone is a lot! tho it works well in car it does smell for about a fortnight after.
bang for buck would be that painted in the wheel arches and floor pan near the tyre. make sure you scrub back the whole area clean and paint on. this will greatly reduce tyre noise.
this could also be poured into the spare wheel well and spread around the area quite thick then have dampening felt layed over that like in my current eg, click my sig link to have a browse.
otherwise flashtac it a cheap alternative to dynamat etc and can be bought in rolls from bunnings. it is used to cover cracks in roofs and can be found in the roofing section under flashing. it is cheaper than dynamat but to have the same affect 2-3 layers would be needed, which in turn up its cost to equal that of dynamat. one layer of this is better than none. areas to do again would be the spare wheel well and boot area, if desired followed by paint on gear and felt. also the outer door skin of your doors, area nearest to the tyres if only wanting to be really sparing, or you can use the paint on stuff but be careful not to block the water drainage hole in the bottom of the door.
i found the wheels arches (including floor pan near tyre), outer door card near tyres and boot to give the biggest effect. flashtac/paint on deadener focusing on large unstructured areas prone to vibrating and those near the noise source would be the areas of most effectiveness and should be targeted first.
you will read in many places about the quality on flashtac. this is purely crap. from my experience and others, i have to say it is all about the surface preparation! clean it back! course rag and prep sol/wax and grease remover. it is just like paint. prep the surfaces as if you were painting it. i have used flashtac many times and will continue to use it as i have never had an issue with it coming off. on the other hand if you ever want it off. just like stock deadener dry ice and a chisel/mallet.
glad to be of help
i'll write up a 'complete guide to sound deadening your vehicle' as a master guide and re type the topics covered here i think. instead of this dragged out thread. something to kill time with on my holidays.
