Originally Posted by GCcorp
NEO Keep Cool 500ml
~ Lowers Operating Temperatures Up To 10 Degrees C.
~ Prevents electrolysis
~ Prevents cavitation, rust and corrosion
~ Harmless to paint and metals
~ Prevents deposit formation
~ Mixes with water or antifreeze
~ Improves heat transfer
~ Contains no chromate, phosphate, borate, soluble oil or heavy metals
~ Keeps thermostats free from build-up corrosion, rust and gumming
~ Does not increase viscosity of water
~ Compatible with all types of radiators
Initial Dosage - Add 110ml of Keep Cool per 20 litres
Racing Maintenance Dosage - Use colour strength-indicator which, fades out as Keep Cool additive is used up. Add 55ml per 20 litres
General Maintenance Dosage - Add 55ml of Keep Cool per 20 litres for preventative maintenance every 4 months or 9,000km, after the cleaning action from the initial dose
NEO Keep Cool goes into a system, softens the deposits and then breaks them down by the molecule -- as small as that -- and deforms their natural crystal shape so that they can not recombine and form solids, and holds them in a soft harmless suspension in the water. NEO Keep Cool has an initial cleaning action which is done slowly (90% in 10 days) and safely so as not to disturb the deposits in chunks which could block small passages.
Advantages
Eventually this cleaning action arrives at the metals, and here it stops because the product is harmless to all metals (including aluminum) and materials in cooling systems. NEO Keep Cool puts an organic barrier on the surfaces that prevents combining with oxygen. It also contains a surfactant: this is a surface-tension breaker which produces improved heat transfer, and is also a preservative.
NEO Keep Cool is compatible with all antifreezes and is superior to water filters and all other water treatments because it provides a complete protection against all the maladies of water systems. NEO Keep Cool is all-organic and bio-degradable, and has passed the government safety tests for human handling so if it gets on skin or in the eyes or mouth, it is non-toxic and non-injurious.
NEO Keep Cool is harmless to paint and metals in the atmosphere. Hard and damaging deposits do not form at water pump glands or other leak points, should they occur.
NEO Keep Cool also has a built-in color strength-indicator and when mixed with water, it becomes milky pink. The pink fades out as the inhibitor is used up. When the pink is nearly gone, add half a dose to maintain safe conditions. When NEO Keep Cool is mixed with antifreeze solution it becomes a milky-whatever-color the antifreeze is, and the milkiness gets weaker as the inhibitor strength becomes depleted. When the milkiness is at half-density, add half a dose to regain safe conditions.
NEO Keep Cool can be used with any water filter, though a chemically charged filter is unnecessary. The old filter may be left in circuit if the system had one before using Keep Cool: it will help to filter out the removed deposits. A system with Keep Cool need not be drained because the suspended contaminants are rendered harmless. However, if the contamination is so heavy (due to the state of the system before the Keep Cool cleaning action) that the color strength indicator cannot be observed, then the system should be drained and flushed and retreated with Keep Cool. A system with expensive antifreeze can be allowed to remain unflushed until spring, provided that more Keep Cool is added to ensure safe conditions from corrosion, electrolysis and deposits.
*** Approved and Recognized by Cosworth Racing Engines ***
NEO Lubricants are recommended by The UK Minister of Motor Sport, Reynard Engineering Ltd, March Engineering, LOLA, Hewland Engineering, XTrac, Prodrive and many other motor sport engineering companies worldwide. Many major racing teams in F1, A1GP, CART, F3000, F3, World Sports Cars, NASCAR, Touring Cars, World Rally, GP Bikes NHRA down to 1/8 scale petrol engine models benefit from NEO products.
