Just recently I wrote to Fulcrum over in WA to ask what the spring ratings were on their suspension that I bought a while back as I've been curious. This was their reply:
These have a progressive rate coil front and rear with the front being
220/260 lbs/inch and rear being 170/220 lbs/inch. You could possibly
increase this up to 50-60 lbs/inch without effecting the shock absorber,
but we have never tried it ourselves to find out how the vehicle will
react.
I'm looking for stiffer springs, and definitely linear types as well. The ones that I have aren't that much more comfortable either. Are there any particular springs that any one here can recommend that will offer a considerably stiffer ride to the ones described above? 50-60lbs increase would be decent without putting too much load on the shock, the fella at Fulcrum says.
These shocks are also height adjustable if that helps.
Cheers!
