DIY. Alligning bootbag to sit just underneath gear knob.
Aim:
To bring the top of the bootbag to the bottom of the gearknob ie. eliminating the small gap where you can see the shifter.
Required:
10mm socket or wrench
Screw driver
Snips
Cable tiers
File
Steps:
1) Remove centre console by undoing the 2x10mm bolts and the 2 screws at the front of the console, then unscrew the gearknob.
http://i188.photobucket.com/albums/z...oto-0949-1.jpg
http://i188.photobucket.com/albums/z...oto-0950-1.jpg
2) Screw the gearknob back in place and sit your thumb going horizontally, with a cable tie fasten it so that your thumb is snug inbetween the cable tie and the base of the gearknob.
http://i188.photobucket.com/albums/z...oto-0951-1.jpg
3) Snip the cable tie leaving aprroximately half a cm. Remove gearknob.
http://i188.photobucket.com/albums/z...Photo-0952.jpg
4) File the end of the cable tie as to not have sharp edges that could potentionally rip your boot bag. (or you could just use snips to round off the dges)
5) Put centre console back together and hey presto!
http://i188.photobucket.com/albums/z...Photo-0953.jpg
Other comments
Was bored one day and decided to see what i could do with the stuff i had lying around =] cheers.
