anyone know where to get one for RB1 in Australia? Dealer service dept charge abt $100 for replacing......
It is $80 from the dealer spare parts department. Replace when it is black.
It should be a simple DIY job to install it, right? if so, I shouldn't have spend $150 + 3% stamp duty on it. I should just pick one up from spare parts department for $80, and just stick the damn thing in meself.
Can you fit one in Euro too? or Euro doesn;t have this design?
DIY. It goes behind your glovebox. Euro has one too.
Would there be one on a 1990 (cb) accord?, behind the glove box too?
Check and find out.
do eks have a pollen filter?
the owner's manual just says it was optional...so how would i know if i have it installed or not?
flwg the owners manual and check out by yrself :) normally its sitting at the back of glove box
do you have pics aaronng? cause i dont know what i'm looking at...
HI PNR888
It is a simple job, so long as you remember to check that about six plastic panels in the base of the tray have been removed. If still in place, the bit of plastic used to remove each one, lifts the element, which then impedes the travel of the air-direction flap. If still there, simply break them out, until you've got a lattice of thin plastic strips. Then just bung the element into the tray, slide it back into its hole, and re-fit the glovebox lid. The Honda 2009 Civic owner's manual shows how to CHANGE the element, but not how to INITIALLY FIT one.
Hope the above helps.
CHEERS
NOEL
$150?????? man.. that is a rip off man.. i offer to chage them for you twice base on $150 for meterial and labour if you in sydney. and i use the honda original cabin filter (active carbon version not the standard version). :P
nothing is cheap for honda accessories in australia... perhaps nothing is cheap here this days.
i have a few laying around which are brand new. I'd let them go for $40 each
Jonny 0416 035 195
