how do i measure what size piping the header has?
just got a cheap xforce one for my car, was wondering if it will fit my stock cat.
thanksssss.
stock is 2"?
thanksssss.
stock is 2"?
On thier site here it says 60mm or 2.3in.
I'm using the same 4-2-1 header,2" pipping and a 2" hi flow metal cat in my car.If your gonna change the header,may aswell get a hi-flow cat too and fix up whatever piping needs fixing.Do it all at the same time.
if ur going to the exhaust shop to get it installed they'll b able to chop/weld anything together for u.
hrmm im not sure which xforce 4-2-1 header it is cause the guy i picked it up off doesnt know either.
just wondering if theres a way i can measure it so i know if it will just fit straight to my stock cat.
im planning to do it at home thats why. however if its too big and wont fit i'd needed go to an exhaust place.
The 4-1 outlet is 63mm so again it's going to be bigger than the stock cat so it will need some fab work.
Measure the inner diameter of the pipe that meets the cat, and also measure the dimensions of the cat flange on both the header and cat side, plus the placement of the bolts.
i was under the assumption that xforce are JDM copies
and all jdm headers are 2.5 collectors right?
although i feel that i am wrong...
Definately 60mm,it says on thier site.It will be fine,just need to fab it up to match cause the stock cat will be under just under 1cm smaller than the header collector.
I would seriously put a hi-flow cat in there as there are gains to be had.Not worth risking a fine for a gutted cat plus Honda's like the back pressure so unless it was a big build you more than likely will lose power putting in a gutted cat.
u'd probably only feel the benefit if u installed it all at once if ur still running stock catback
so may as well wait and then u'd know for sure if everything lines up
lol yeah i think im gonna wait till i get everything then do it all at once.
Yeah sux's waiting but you know what they say,do it once do it right!
Just do another mod/DIY if ya got time on ya hands.Plenty to do.Did ya see what I did to My Boot recently.I LOVES IT!
btw Thanks for da rep Yo!
and the wait begins!
good work on the booot!
i've been wanting to do something to it for a looonng time. wanted to give it a very good clean and custom make anew piece of wood thats a tad bit strong so it doesnt bend when my sub sits on it. and to have a little latch on it so i can open/close it and store stuff under.
prob get to it these holidays
Thanks mate!
I just want to keep my car as light as possible.With the 6x9 speakers in the rear,it's plenty of bass.
