does anyone have the oem template to drill holes??????????
or can anyone shed some light..................
cheers
cheers
Hi mate!
If there were meant to be holes drilled to accomodate the pods, you'll need to take the rear bar off and check on the inside. If there are OEM holes, they will be marked by a small circle approx 7mm in diameter, with slightly raised 'pimples' on the surface, and a larger dot exactly at the centre.
They're very hard to spot, might even be worth getting a little metho and wiping the black grime away from the area.
Cheers! Dan.
cheers mate, i have the bar off, and i cleaned as best i could with cloth and water and no marks or circles seem to be on the bar on the bar..............
i will use metho tomorrow and check again
thanks
i also couldnt find the dimples on the rear bar..
im guessing yours is original?
yeh man...............i was out there for 1 hour with metho on the inside of the bar trying to find circles and dimples and crap.......lol
i just rang my mate at honda for a template that the dealers use to install....
i'll let you guys know how i go............
yeh i have original dc2r rear bar and oem rear pods...........
will see what happens
hey tom, where did u get the oem rear pods from? able to get more :D
Thats annoying, I would have thought there might be some marks for the holes.
When I was working on my EK, I got a EK9 rear lip and wondered for a little while about how I was going to get the holes to be accurate enough so that the lip sits snug against the bar - then on closer inspection after a little wipe-down on the inside of a stocko-standard EK1 rear bar, I found the markers for the holes!
Cheers, D.
yeh thanks mate.........i assumed the same, maybe i'm just blind................
but no need to rub it in that urs was so easy........lol.......jks
ill check the facelift bars i got a home and see if theres any holes of nipples on the inside for ya
Hey bro...
i just drilled my own holes into the bar..
one screw into the wheel well area and another screw into the slot where it wraps into the air dam!
it was easy... when holding the pods up against the bar, it might not look like its a perfect fit but once you screw the pods on, you can adjust them to make them fit tight.
hope that helped
thanks mate, but i got oem ones, so i dont have to screw them from the outside.............................
i got all the brackets and nuts and bolts with them.................so i just need the template, coz im either blind and cant see the dimples to drill, or they are not there
just sell them to me ;), no need for this hassle lol
Just get rid of them mate they add too much weight on the car.
i saw the pannel beater fit my original ones...
just line them up then mark with texta... then drill!!
i was like.. he better know what the @#$@ hes doin
There is no dimples. You need to drill a hole, approx where the Pods align. Peter from Bodyform, did mine whilst the rear bar was on the car. It took him 20 mins to do, first time aswell. He's GOOD! Quite annoying, how the measurement tool that honda give you is a piece of a paper to align the holes. And that's all. If I were to be doing it myself, i'd fail miserably. Good luck mate.
thanks teaseR
VTECMACHINE - how can u measure and mark to dril, whilst the bar is on the car????
the brackets on the pods are visible from underneath...............
g-stick.....give mer cash and they urs............
blulude98- i got power, so no need to worri about weight, unlike ur car.............hehehehehe......lol
There is no nipple. You just need to drill through the middle of the bar. But aligning the brackets on the pods. Like I said.. Peter from Body form is good - but he's in Sydney. He'd probs only charge like $40, and have them done in 20 minute.
yeah mine was done on the car too but im from adelaide +)
