im taking my car in to get some of the bagdes removed, i have a graphite 03 euro, ill post some pics of it as soon as some one tells me how i can add pictures to my thread?
cheers
cheers
To Add Images Read: http://www.ozhonda.com/forum/faq.php...b3_attachments
are you paying someone to remove the badges for you? the rear badges ?
it is easily diy able. hair blower with some floss or fishing line. peel off. wash. claybar. wipe polish. wax. done.
everything except the honda badge
Use bug and tar remover to remove excess glue
clay bar should be fine to clean it nicely.
WD40 works a treat too...lots of elbow grease involved.
Or just park your car in the sun on a hot summers day then remove it with floss in the arvo :p
I did mine a few weeks ago and it took aaaagggess. I tried hairdryer but my car was parked under a carport so the hair dryer had minimal affect.
here are the pics, just washed it today and gave it a nice wax
^ not bad! Not a fan of chrome but i must say that doesnt look too bad ;)
I'll be in Adelaide next year for a year for work, maybe do a little meet lol
You lowered at all? Are they 18s?
yer there 18s, it used to have stock 16s and the car sat really low, i think it had the sports kit. but wen i got the new rims on, it raised the car alot
what do you think of it?
dump it mang & ditch the chrome!
cheapest just low springs ---> will result in you having blown shocks
airbags speak with kitbkk should be about 6k+
reliable and comfort/sports - bilstein/eibach/konis
performance - coilovers
your chrome ain't big enough though.
you need at least 19 to look pimper
hope this helps.
i couldnt go any bigger other wise i would get defected, and the cops are harsh as hell on p platers, my window tint is already illegal.
so buying spinrgs that lower an inch or 2 are bad for the car?
what do you mean by blown shocks?
how bout cutting the srpings?
What size are you running now 18"?
cutting springs + lowering springs equals to blown shocks(damaged and worn out) if you don't replace.
stock shocks are fixed to a certain height and running the car lower results in increase wear of the shocks, hence you need shocks to fit the height your lower to.
Cutting springs is a typical cheap method, i recommend not to.
If your goner change your shocks, change all four.. otherwise dont do it at all.. NO point changing 2 shocks, and having to change the other 2 later down the track anyway..
If you want something relatively cheap and good for handling than i'd so go for some koni shocks, otherwise shop around abit...make sure when you shop around for shocks to mention its for a lowerd car
