List things you should and shouldn't do on a bike?
do a wheelie, or speed on the road =)
show off
dontt armour all your tires!!!
LOL
Dont ride with your helmet on backwards.
dont ride naked
dont buy one if you trying to save petrol
Don't smoke while you are driving...
Dont mistake the brake for the clutch.
*sigh... this thread really phails...
Go take a few lessons Tubby - it will be MUCH more valuable than asking such an open-ended question here :)
yup, chances of actually getting the info your lookin for are pretty slim, theres lots of things to do and not do, netrider has a pretty good beginner list for riders
Don't forget to tighten up your helmet straps!
I did that the other day, took off down the highway and realised OMG I didn't even tighten the straps. Packed sh*t!
Make sure you dont ride if you have had a big night before. Throwing up in a helmet = not fun.
Yuck.
Don't stick your finger up at patchies.
LOL.. just flick off anyone you can!
ive coughed in my helmet before lol !!!
I've sneezed... there was mucus on the shield, had to stop, take my helmet and wipe that sh** off, was laugh at how it would have looked from the outside.
do : ride with a singlet and shorts in the warmer seasons, summers around the corner/ Race all hondas you see,
dont : race mini cooper supercharged lost against 2 [ PE99i3 ] LOL
^^ u lost 2 a mini - wot r u riding a cbr125? neway...
Tubby - you asked the most open ended q ever - and thankyou all for your fantastic comments
Heres a real one though - dont ride tired - and wear appropriate gear for the weather - no fun when your wet and cold.
and plus 1 for dont ride naked - LOL
tubby if u ever rode naked i think teh cops would put you away for life LOL:wave:
Hey guys.. I got this info from 600rr.net and found it very very helpful. Its great to see the number of riders increasing but alot of them are not prepared well enough to hit the roads safely (altho riding is not a safe activity fullstop lol)..
Watch drivers' heads and mirrors
Watching the head movements of drivers through their windows and mirrors is an excellent way to anticipate sudden moves. Most drivers won't lunge left or right without first moving their heads one way or the other (even if they don't check their mirrors).
Trust your mirrors, but not totally
Your bikes mirrors can be life-savers, but they don't always tell
the entire story even if they are adjusted properly. In traffic, always buttress your mirror generated rear view with a glance over the appropriate shoulder. Do it quickly and you'll add an extra measure of rearview and blind spot knowledge to your info gathering tasks.
Never get between a vehicle and an off ramp
This sounds almost too simple but drivers who decide to exit at the last minute kill plenty of riders each year. The simple rule then, is to never position yourself between a vehicle and an offramp. Passing on the right is generally a no-no, but in this day and age it's sometimes necessary. So if you do it do so between exits or cross streets.
Cover your brakes
In traffic, you must often react very quickly, which means not fumbling for the brake lever or pedal. Always keep a finger or two on the brake lever and your right toe close to the rear brake pedal. When that cell phone-yakking dorks cuts across your path trying to get to the 7-Eleven for a burrito supreme, you'll be ready.
Be noticed
Make sure drivers and pedestrians can see you, even from a distance.
Ride with your high beams on during the day (as a courtesy turn it off when sitting behind someone at a light) and wear brightly colored gear, especially your helmet and jacket.
Be ready with power
In traffic ride in a gear lower than you normally would so your bike is ready to jump forward instantly if asked (not everyone rides open-class twins after all). Doing so gives you the option of leaping ahead instead of being limited to just using the brakes when that pickup suddenly moves over. The higher revs might also alert more cagers to your presence.
Traffic slowing? stay left (or right)
When traffic slows suddenly stay to the left or right of the car in front of you. This will give you an escape route if needed. It will also keep you from becoming a hod ornament if the car behind you fails to stop in time. Once you've stopped, be ready; clutch in, your bike in gear and your eyes on the mirrors. You never know.
Practice the scan
Constantly scanning your entire environment while riding-from instruments to mirrors to the road ahead to blind spots to your left and right and rear keeps you aware and in touch with your situation, and therefore better able to react. Dwelling on one area too long; watching only behind or in front of you, for instance, is just begging for trouble.
Left turn treachery
When approaching an oncoming car that's stopped and about to turn left, be ready. Your bright should be on so the driver can see you (during the day) but don't rely on this to save you. Watch the car's wheels or the driver's hands on the steering wheel if you see movement be ready to brake, swerve or accede, whichever seems best for the situation.
Study the surface
Add asphalt conditions to your scan. Be on the lookout for spilled oil, antifreeze or fuel; it'll usually show up as shiny pavement. Also, keep an eye out for gravel and/or sand which is usually more difficult to see. Use your sense of smell too; often you can smell spilled diesel fuel before your tires discover how slippery the stuff is.
Ride in open zones
Use your bike's power and maneuverability to ride in open zones in traffic. In any grouping of vehicles there are always some gaps, find these and ride in them. Doing so will separate you from four - wheelers, give you additional room to maneuver and allow you to keep away from dangerous blind spots. And vary your speed; riding along with the flow can make invisible to other drivers especially in heavy traffic.
Use that thumb
Get into the habit of canceling your turn signals often regardless of the traffic situation. A blinking signal might tell drivers waiting to pull into the road or turning left in front of you that you are about to turn when you aren't. So push that switch a few times each minute. Better to wear out that switch than eat a Hummer's hood, eh?
It's good to be thin
A huge advantage single-track vehicles over four- wheelers is their ability to move left and right within a lane to enable the rider to see what's ahead or through their windshields, seeing what's coming can give you lots of extras time to react.
More than one way out
Yeah, motorcycles fall down, but they're also light, narrow and hugely maneuverable, so you might as well learn to exploit their strengths when things get ugly, right? So don't just brake hard in a hairball situation. There's almost always an escape route. Swerving into Mrs. Smith's front yard could be a lot better then centerpunching the Buick that turned left in front of you. Always have an escape route planned and update it minute by minute.
Running interference
This one’s easy and we'll bet most of you already do it; let larger vehicles run interference for you when negotiating intersections. If the bonehead coming toward you from the left or right is going to blow the light, better they hit the box van next to you, right? For the same reasons, don't lunge through an intersection as soon as the light turns green. Be patient and use the vehicles next to you as cover.
ADDITONAL INFO
thanks Backstreet
Practice quick safe stops on all road surfaces and conditions. Learn the distance you can stop within. If you go 75+ know how to stop from 75+. This gives you a better appreciation for speed and following distances.
Look as far ahead as possible especially around corners. Scan but use your side vision so you always have "one eye" looking ahead. Limit your speed so that you could stop within the distance you can see ahead. One day - you will have to stop.
My new one I'm working on is to keep track of how warm or cold your tires are during the ride. Know how much tracition you have available. My tires went cold last week as the sun went down and I slid the rear under power out of a turn.
