Hi guys I'm getting 2 aftermarket gauges installed into my car and the auto electrician has asked me to supply an 'ecu pin wiring diagram' for my car. Any idea how I can get this? My car is a 96 accord.
Cheers
Cheers
Should really come and join OzAccord.net/forum
What gauges are you putting in?
http://honda-tech.com/showthread.php?t=2377726
But you have an OBDII
So
Here you go
http://honda-tech.com/showthread.php?t=413140
Thanks mate you're a champ! Installing an oil pressure and oil temperature gauge. Might add a voltage gauge later down the track if I feel I need it
Fair enough for the oil pressure and temp gauge
I'm sure you can piggy back the connectons from the back of the block instead of at the ecu
Voltage gauges
http://www.ebay.com.au/itm/12-24V-LE...bdcc09a&_uhb=1
plug it into your cigarette light socket
Curious why the oil gauges for?
I have an oil leak in my car which I wanted to monitor but also I'm getting some head work done soon and wanted to make sure my car was at normal operating temp before I decide to put a bit more for force on the accelerator. Just mainly for monitoring purposes
Ahh find out where the oil leak came from?
Some obvious places are
dizzy o-ring, valve cover or vtec solenoid
I found the leak to be coming from the oil sump, seems like its a big job to do/hard to get to
Oil sump?
Remove ehaust
A few mounting bolts under the transmission - if auto
And change the sump gasket
