wat mods for this??
hey guys im going to buy a 95 96 honda accord exi and just wondering what size rims can fit under it without any mods to the suspension or rolling the guards ive got a 87 model atm but 17s scrub just dont want the same problems with mods as ive had in the past with the 87 any info would help alot thanks guys.
Um... Welcome.. But if u had a quick look at the other threads that are posted even on the first page of the "Accord" Section.. about 3-4 threads are about your year model acccord and fitting wheels for it...
But basically 18inch is as big as u go before u start having problems..
you mean your not goin to drop it? i'd recommend 18 and lower it 2.5 inch at least then your set
17s ireckon... or 16 for form over function.
Just get 17" rims of the correct offset, use thinner tyres to maintain the original rolling diameter and ensure that the tyre width is not outrageous. That should avoid scrubbing.
id go 17s but still... you'll get bad 4wd height.. lowered on 17s look fine
215/45/17 is fine with a mild drop, or should be lol
i got 18's with 215 tyres and a decent drop and no issues. guards havnt been rolled either.
19s can be fit without issues on stock height (depending on offset and tyre profile).
once you go lower, your wheels will begin to scrub. Your safest bet is 18s with CORRECT offset and a tyre profile of 215/35/18 which will allow you to drop your accord 3.5inches without a single scrub or modification to your guards etc.
