B20 with B16B head??
I have been searching for this combination but i cant find anything that i am looking for
I am thinking of getting a B20block, going oversize, forging it out etc but i just want to know if the b16b head will fit, if i was wanting to run around 12-12.5:1 compression ratio pistons, what waterpump and oil pump should i run? Also would the standard B20 crank be fine for hanging around the 9k mark?
Thanks
Yes this combo has been done before.
No the standard crank will not withstand 9,000rpm reliably.
If you need any forged internals or camshafts, drop us a pm to discuss further
wouldnt you be better running a B18c2 head instead! or b18c7
wats the point of revving to 9k. u wont need to rev that high just to get moving with a 2lt.
And what's the point of running 12-12.5:1 compression?
Because race car?
Most people asking this kind of question have never been in a car with a standard b20 block with a standard b16a head and would probably be surprised at how it feels.
No point using a stupidly overpriced b16b head when you can get cams for a b16a head. No need to go 12+ on CR either.
^^^^ correct, whats the point of doing things?? Race car???
stock b20 is pretty good on its own
oversize is a no no unless ur sleeveing the block
for that much compression and revs your thinking, you better have a good tuner
which are pretty rare to find these days
all these questions have been answered twice over in the b20 discussion thread
