My dc5 type r for some reason pulls to the right a lot when I acelebrate hard. It's not alignment issue because I've checked it out. Any ideas?
Maybe sussy bushings getting old?
How's the engine mounts?
If it's not an alignment thing, then perhaps you should get the wheels checked out. Not in terms of alignment, but just to see if the treads and all are in order. It can be quite a dangerous issue if you are used to travelling at speed. Get it looked at if you're not feeling safe to handle the issue when you're on the road.
seems like your describing torque steer
Could be torque steer, could be diff issue, could be tyres, could be wheel bearings, could be anything...
Best to describe more...
coulld be something bent causing that steer to go right
