Hmmm. Just unplug it :P but I think it’s under the dash labeled pgmfi.
Cheers. I’ll check it out. I thought it was under the bonnet. I can’t access the boot area. Cars been sitting for 5 months getting the engine/box rebuilt. Just trying to wind the motor over for oil pressure before it fires up.
I’m excited lol.
All done cheers [emoji6]
Well motor fired up nicely. I’ll have to wait a few days before I can take it for a run.
This whole process has dragged on a little lol. Shoulda just saved a little and bought the new turbo Type R.
Too true lol.
Drives great! Good to take it for a run and not have a black rear bumper.
Everything feels good. Clutch, gearbox etc. no check lights on the dash etc.
There is a lingering issue that affected the motor prior to rebuild and still does. As it comes off a cold high idle and you are driving, if you come up to a set of lights off the throttle it almost stalls. Once it’s hot it’s perfect. It’s sort of that initial 3 to 4 minutes warm up period.
I had an old Pulsar with this issue and it was an idle up solenoid?
Could it be the same? Clean up or replace?
Well after 900 kms the motor has freed up a little and driving sweet. Lol.
It’s been a long project lol. Finally!
Started off at around 10L/100kms and now getting 7L/100.
Oil pressure is getting to 75psi at 2000rpm.
So far so good.
Nice work. I had idle problems that turned out to be dirty Throttle body and iacv.
Thanks. I’ll get in there and clean things up with some carby cleaner. See what damage I can inflict lol. Apart from that I can say things are perfect.
Fellas, is carby clean safe enough to spray into this IACV?
It looks like a concertina style rubber boot. I know what carb cleaner does to rubber.
I used brake cleaner but took the rubber gasket off first.
Well I used throttle body cleaner. It’s worse. Lol. Stalls constantly now coming off revs. Bloody pain in the butt.
I’m getting over this car real quick now lol.
I have a perfectly reliable turbo diesel Hilux that just doesn’t play silly games. Lol
