Head unit not turning on
I have had my car for almost 2 years now and the head unit has turned on every time. But just now I was checking some of the leads at the back and I had turned the head unit off; key in but engine off.
I saw the antenna cable was loose and as I put it back the headunit area made a 'beep beep beep' noise that usually sounds when I turn off the car.
Any help is appreciated thanks!
Oh the cigarette lighter hole also doesn't charge now too...
check fuses
might be blown
^^ must be over 550cca's for that hi performance feels.
You must spread some Reputation around before giving it to lolmclol again.
Thanks guys yes it was a blown fuse - cigarette/ radio fuse. All good now!
