robotic_dyno_bed_in
http://spectrum.ieee.org/img/stahle%...6386687051.png
robotic_dyno_bed_in
http://www.exedy.com.au/faq :)Quote:
Do EXEDY clutches require a break in period?
We recommend breaking in the clutch for 1,000 km with mild engagement such as stop and go city driving prior to racing or spirited driving. Do not overheat the clutch during the break in period.
im sorry but the same can be said for motor oil, brake fluid or tomato sauce in a bottle. im sure your method would have the resulting fluid that remains in the box would be cleaner but its very very excesive but if you where using an engine oil in the box like alot of ameriacans do the cost is significantly lower so why not i guess
Since when do you need a wheel alignment after changing a clutch? Pretty sure the only thing that is touched suspension wise is the lower ball joint which does not effect the alignment.....
