Integra VTiR G/box Reliability Non LSD
hey all as iv posted before, i had a input shaft bearing problem on my gearbox and it turns out the differential is making horrible sounds aswell so it looks like it has to be replaced.
Iv got three options replace the bearings and put a second hand open diff for $500-$600, buy a second hand gearbox for around the same but ISB problems could arise in the future, or fit an Mfactory helical with bearings done for $1300.
Iv done some research but not much info on the Y80 box that i have right now, does any one know if the gearbox will be able to take the pressure from a aftermarket LSD?
I dont want to get all this work done and it ends up blowing(I wont be clutch dumping at 6000 probably 4-5 if i take it to the track), last owner of the vehicle absolutely thrashed the car clutch was worn down to very end, flywheel bearing completely stuffed, my mechanic told hes surprised no slipped or crunching occurred.
Im going to be doing the following Mods in the near future:
Buddy Club Cams
Skunk2 IM
Skunk2 TB
Full Exhaust
Hondata.
Let me know what you think, thanks.
