Moving engine lower in engine bay?
Just wondering about dropping my engine by a few cm in the engine bay for better centre of gravity
Basically there are 4 mounts. Front, back and 2 sides
Front/back are on an I beam which is connected to the crossmember and just under the radiator onto the chassis. Just wondering if I could get longer bolts and use some spacer plate there
The side engine mounts are in a similar design where I can pretty much put spacers to drop it down
Wondering, any downsides besides ground clearance?
Or could this actually be as simple as about $50 in materials and some DIY work to drop it down roughly 50mm?
