hey guys, last night i noticed my petrol guage isnt lighting up with the rest of my dash and also half of my speedo is sort of dimmed , anyone else had this problem? or know how to fix it? im thinking its the fuse but i just want to make sure thanks
if theres still a light in ur dash means thers no problem on the fuse...try to change the bulb in ur dash t10 is rigth size.
Its easy enough to pull out the cluster and check if the bub is blown.
To take of the cluster 'suround' theres 2 screws underneath. Pull out the suround. Then you now have access to the cluster screws. Undo the screws and you can now pull out the cluster, to access the rear. Take out the bulb in question and check/replace. I don't think you'll need to remove all the plugs. So turn on your ignition etc and test if it works before putting it all back together. :thumbsup:
arent the t10 bulbs the same light bulbs as the parkers??
yup.......
