As long as the swap is no bigger than 15% in capacity. There will be no hassles.
Hi guys, I brought a b20vtec from a member here a months ago now. Okay here's my story I'm getting my car tune (car still at the dyno) we have been having problem with my car, when the engine is hot the car backfire and Also ill be running 3 cylinder for like 2-3sec then it stop and comeback to 4 cylinder. We change the dizzy, spark plug wire, change ecu, change TB. Still doesn't solve the problem.. What could the problem be?? I just want the car to run good and don't miss cylinder. If any of you guys experience this before please share your thought. Cheers
yeah you just rotate it?
I know it's elementary but did you check/change the actual plugs?
Well the dizzy from my old car I haven't change or touch ever since I brought the car, 8-9 months ago so yeah... I've done some reading on the net and most of the people recommended to change/check your spark plug wire. Will it be okay to drive it now? Cheers guys
Ctrek9 you should open new thread for your engine issues. Even though it's b20vtec, it's technical issue not a discussion abt building b20vtec
take it to a reputable mechanic if this one is just shotgunning it and replacing everything, how is it running on 3 cylinders? no spark or no fuel? if theres no spaark u will smell the fuel, if its the injector try using a noid light to check individual injectors, also check if the ecu is throwing any codes or even better, try uning a scanner and showing some live data
Hey guys, anyone here from Melbourne that has actually had or gone through a b20vtec? If so could you guys please help me. I'm contemplating on doing a b20 vtec swap into my ek4. Just want to know if their are any reputable b20 vtec builders & tuners in this area. If someone could get back to me via pm it'll be much appreciated.
For Melbourne I would hit up Josh @ Sleeping Performance
