Installing a Breather KIT onto a B20VTEC/LSVTEC
Aim: To Install a Breather System onto your B20VTEC/LSVTEC block ( while it is in the car)
Required:
Socket Wrench, Tool set , Allen HEX Key, Phillips/Flathead screwdriver (depending on how you want to tighten the clamps) Jack stands, Jack, Shifter
2 X Honda Prelude Breather Bung : 11107-PK2-003 ($50 for both)
2 X Honda Washers : 12207-634-300 (i reused my old ones)
4 X Clamps 15mm ($4)
2 X Pirtek Water/Oil Resistant Pipes 15mm ($12) ( or you can use any water/oil resistant pipe)
and
most importantly your
Breather Can ( i bought mine from ebay $50)
http://img560.imageshack.us/img560/9669/img1041s.jpg
Steps: Opening the bungs ( i didnt have the tools to remove the bung so i took it to GPC who did it in about 5 minutes)
1. Need to Jack the car up on Jackstands.
http://img842.imageshack.us/img842/6826/img1009bd.jpg
2. Get underneath the car Locate the Bungs and use allen HEX key with socket to undo (image borrowed). It may be possible to do it above the car removing intake manifold but this was is easier
http://i17.photobucket.com/albums/b7...mQzMXk1NDE.jpg
Now there is little room when the the oil filter and subframe is in the way so be prepared for a tight squeeze, when you crack open the plug is pretty simple after that.
Pics of Plugs removed
http://img194.imageshack.us/img194/2201/img1045mr.jpg
3. Fit the Breather Bung onto the hole, and tighten with a shifter
http://img28.imageshack.us/img28/9709/img1051br.jpg
4. Fit Hose onto to Bung and feed clamp to end and tighten
http://img24.imageshack.us/img24/5084/img1047tu.jpg
I found that the rest can be done from above so i removed the battery and had lots of room to fit my hand thru for the rest of the procedure
http://img841.imageshack.us/img841/6056/img1049tf.jpg
http://img217.imageshack.us/img217/5941/img1053b.jpg
5. Connect all pipes together with clamps, mount your catch can and your ready to go!
http://img8.imageshack.us/img8/9131/img1055j.jpg
Other comments
When building a hybrid to make things easier just remove plugs and fit the bungs before dropping them in, but if already dropped motor no need to fret its not that hard to do..
Use at your own discretion venting with mini air filter exposed out is like a normal pod filter, you will get defected.
