(DIY) Replacing Tie-Rod end (EK) With PICS
hey guiz and gals , i will be showing you how to replace a (tie rod end) , very bored and have nothing else to do so why not. :)
ok lets get started !
tools needed : Pliers,Socket Wrench , and i used a special tie rod end removing tool which i got from supercheap auto for 30Bux
http://img690.imageshack.us/img690/5...0308172942.jpg
you also need a jack and jackstands .... Duh . :D
Loosen up lugs before jacking all the way
http://img191.imageshack.us/img191/1...0308173443.jpg
now once jacked up remove wheel or Wheel(s) :)
http://img713.imageshack.us/img713/6...0308173805.jpg
okay now lets get crackin
http://img703.imageshack.us/img703/8...0308173810.jpg
Remove pin with pliers
http://img546.imageshack.us/img546/6...0308173836.jpg
using a 17mm socket remove the castle nut
http://img545.imageshack.us/img545/8...0308174237.jpg
http://img10.imageshack.us/img10/563...0308174402.jpg
using a wrench / i think this was a 19mm loosen jam nut but not too much
http://img6.imageshack.us/img6/7547/...0308175008.jpg
Fun part starts here :D using the tool from supercheap gently use the fork bit and snug it up under the rubber and the bottom bit should force up ( you will notice it Pops out ) then twist tie rod end of while holding inner tie rod (Leave JAM Nut on! as it helps position it back on )
http://img844.imageshack.us/img844/9...0308174418.jpg
http://imageshack.us/scaled/landing/...0308174528.jpg
http://img32.imageshack.us/img32/890...0308174717.jpg
http://img577.imageshack.us/img577/9...0308174821.jpg
compare the product before installation to make sure everything is correct!
http://img16.imageshack.us/img16/585...0308175251.jpg
http://img818.imageshack.us/img818/6...0308175255.jpg
yup all good , now installation same as removal twist back on back to where your jam nut is count how many threads are visible for my ek it is 6! use a flat head and place in threads triple check this process as it helps for when you get alignment
http://img836.imageshack.us/img836/9...0308180619.jpg
pop it back in to place , tighten new castle nut on and look for the hole where the pin goes and just bend the pin outwards
http://img837.imageshack.us/img837/3...0308180527.jpg
http://img201.imageshack.us/img201/9...0308182026.jpg
tighten up the jam nut and thats it you just replaced a tie rod end!
http://img441.imageshack.us/img441/4...0308182114.jpg
put wheel back lower car and just do small and slow test drives around the street try to feel/listen to anything out of the ordinary if not your good to go :) Good luck!!! :)
