hi there i check my ecu for fault i get 37 and 14...whats 37??can any1 help me with this...thanks
Today I tried the test The engine light switches off initially and comes back on and stays on does that mean its 10? or there is no fault?
it means no fault
I just tried out your DIY and i got 61 but it was my ABS light flashing and Engine light just stayed on.
primary Oxygen sensor
i have problems starting my car up in the morning or leave the car sitting for over 8 hrs, it starts up like the battery is dieing and then turns over and starts.
tested the battery and its fine, would this sensor cause a difficult start?
was just looking at the codes u put up my ? is what isan ignition output signal thats what is coming up on mine ?
hi guys i just check mine i got 1 blip and 1 long blip.. what is it..?
If I'm interpreting correctly, you have a code 1 and code 10, see the first page for what they mean.
grifty the check engine was gone but the idle is dropping when i rev it then release it the rpm drops.. any idea..?
Clean the IACV and adjust idle correctly.
guys wanna know code 11 is..? i have called my service shop super visor back at HONDA CARS PAMPANGA PHILIPPINES (where i currently work as a auto painter and under chassis mechanic) CODE 11: IMA sensor meaning IDLE MIXTURE ADJUSTMENT.. just to add and share the info guys.. hope might you the others in the future..
I just got a new cluster, and the CEL isn't lighting up (even with the key on II) I used to have the Non-Tacho cluster before that doesn't have a CEL either so i'm not sure if there's something wrong with my ECU or something.
PS: I already swapped the bulbs behind the cluster and the CEL is still not working.
i may be wrong (someone to 100% confirm this??) but for some EK owners the plugs are not on the left side of the passenger footwell but on the right side.
for my brothers gf car thats where it was located, and there was no big green plug, it was blue. you'll see the 2 blue connectors, one that 3 wires, the other has 2 wires (brown and black).
