Originally Posted by
DreadAngel
I think he means Non ABS as in remove all the ABS gear completely while disable ABS by just removing the fuse or something along those lines?
OP - Like Senna mentioned previously, all ABS's are programmed differently and even ABS between same model can differ due to wear & tear, different tires/wheels, etc. Some are indeed intrusive, others will only attempt to save your from your own bravery =P
Best way to determine is to go out there and try it yourself ;) As you develop, you'll slowly figure out if the ABS helps you or a hindrance. I found for myself personally, non-ABS allowed me to perform much more delicate braking but I've had to work on getting myself use to modulate the brake pedals in emergencies instead of simply stomping on it. Pays to have a correctly selected brake setup and tires =)
