your above pic will work, but I dont recomend it
you really should be using a relay and a fues.
get an automotive relay from jaycar
cat #
CAT. NO. SY4068
and geta relay base while your there
CAT. NO. SY4069
cat #
CAT. NO. SY4068
CAT. NO. SY4069
Any one have the wiring drawing for EG fog lights?
How, where to cut the bumper hole to hold the EG6 fog lights?
thank ECU-MAN, atm i'll keep my current setup. when i can be bothered i'll get the relay and base.
have u wired ur foggies yet man?
i want to wired up me foggies too
u reckon u could give me a hand?
I've hooked up my foggies onto my car and is fairly easy.
However i had the wiring harness so it was plug and play. But I may be able to assist with creating a wiring harness from stratch so long as I can see the base electronic diagram to refer to.
What sort of wire do you use for wiring ?
i got mine in and working with the help of a mate... BUT they work for only 5-10mins then the fuse blows :( we have searched theu to find a problem but cant seem to :(
any ideas? ive blown 15amp fuses up to 30amp
here u go guys ... tho someone would of posted this link already ?
http://honda-tech.com/zerothread?id=1352749
what exactly is the relay used for ???
what would be wrong with wiring it up like this
http://img.photobucket.com/albums/v1...K/circuit1.jpg
lol u need the relay. on my old car it use to turn the lights off when the car would turn off and only turn on if the headlights were on at the same time too...
anyway when my mum bought her lancer she had foggies wired up ur bodgy ways and the switch kept getting hot, didnt feel too safe...
hmmmmm and what gauge wiring should i use ?? my foglights are 35w..
The thicker the better.
Also using a relay makes sure you don't actually blow your switch or anything else that is apart of the wiring.
Its easy and cheap. Just do it.
