I got mine from hondapartsdirect.com for about $11
But shipping to Aus is $50
But i got alot of stuff $130 worth
So shipping worked out to just over $70
ok looks like the head gasket is on its way out, i have reinstated a thread elsewhere regarding engine builders in melbourne, if the head is coming off may aswell have it inspected and look into options regarding modifications.
What evidence brings you to that conclusion?
traces of water in the rocker cover and a milky substance under the oil cap, going through coolant and it seems to be running a few degrees warmer than normal, from my understanding that sums up a head gasket? what do others think?
yep I agree, by the way is anyone on the same page as me regarding the above? I am assuming its worth purchasing a OEM head gasket, with the head off I guess valve stem seals are worth doing? I am on a tight budget, would love to install different cams but not sure if I can stretch that far.
Yes OEM VRS Kit should be a must for you at the moment. I bought mine from JDMyard for $320 i think.
If you could stretch out, I mean your already paying for the most expensive part and they probs gonna charge for OEM replacement.
Option out for these at minimum - SuperTech B Series Super Valve train Combo Wombo
(you can find it cheaper on other sites)
This way, if you want cams in the future. Just drop em straight in and tune.
My True and Honest Advice - The Days of BWAHHHAAA are numbered now, do cheap full OEM rebuild. Sell her off before she looses too much value. Damn new laws.
If you are taking the head off because of a head gasket , there's a chance the head will need skimming / machining too.
You can't do this stuff on a budget - it really has to be done properly and no expense spared. Just get the head off get it checked and go from there.
yes I think that is the way to go, remove the head and see whats what
budget might be the incorrect word, basically want to spend least amount $$$ possible but still have a quality job, happy to keep everything fairly standard if it is a substantial amount cheaper, I know porting and polishing is $$$ so I will stay away from that but maybe increase the compression slightly, cams ?? heard they add up so they can stay if still ok etc
Who do you guys recommend to take the head too - in melbourne - south east, bayside?
Cheers
Just don't get duped into someone recommending a quick headgasket swap. Chances are you'll need it machined like ben said. If you DO need it machined and you just change the gaskets over, you'll get the same problem again in the near future and then you'll either A) get it done again properly B) Get pissed off and sell it.
Shop around for someone reputable.
You get what you pay for.
yes that is true, always get what you pay for
Ok head gasket not confirmed, i am confused
drained the oil, looked perfect, no signs of coolant, refilled oil, started engine, looks like a light grey/white smoke when cold with water/condensation from exhaust pipe, I also bleed cooling system again.
once engine is at normal temp and electric fan kicks in, the smoke disappears and no water/condensation out of exhaust pipe (assuming its due to been quite hot)
let engine cool down ,a milky residue under oil cap, coolant level in overflow catch tank went down slightly?
has anyone had a leak down test done on their car, would that be worth it?
could coolant be leaking internally somewhere??
cheers
