Do you mean the drivers side clamp where the bushings go? I'm running white line rsb and tegiwa exhaust which is a copy of rm01a and no issues
Not the clamp/bushings. The sway bar has completely separated itself from the end link.
O shit. I got aftermarket hardrace end links. I hate the stock end links since they're the biggest pain to remove with Allen key
Looks like you're set up the same as me. How come you have no rattles? Are you stock suspension? Which hole did you use for the Whiteline?
I'm lowered on coilovers and using the firmer setting.
Plenty clearance
https://imageshack.us/i/pcVhDea5j
I'm lowered on coilovers and I'm
May be it's the coilovers. I'm on stock.
Or take ur car to exhaust place and I'm sure they can modify the hangers
Got it sorted temporarily. I adjusted it to the softer setting. It was vibrating whilst it was 24.5mm.
23.5mm doesn't touch, so I'm happy with that.
And I've realised the prices for these Whiteline sway bars have increased.
hey guys whats the part number for the ep3r 1st gear synchro?? I cant find it
Does this help?
http://jp-carparts.com/honda/partlis...fig=M&fig1=500
Anyone done a facelift headlight conversion onto Pre facelift EP3?
If so what parts are needed and is it a direct straight fit?
