New Honda/Acura Auto Transmission Fluid: ATF DW-1
Kudos to Mr. HeelnToe:
Quote:
New ATF DW-1 Now Available
Acura parts stock has a new ATF available. It’s called ATF DW-1 and it replaces ATF-Z1. It’s been
designed to improve transmission performance when it’s cold, which helps with fuel economy.
ATF DW-1 is the factory fill for all ‘11 Acura models. Eventually it will be our only ATF, but you can keep
using ATF-Z1 in all ’10 and older models for now. However, make sure that you DO NOT use ATF-Z1 in
any ’11 and newer models.
ATF DW-1 is available in 1-quart bottles (P/N 08200-9008A).
Source: http://www.heeltoeauto.com/files/pit.../sn_atfdw1.pdf
