Does anyone know if this will fit and work in a cl9 pre facelift (the clock on the dash cover)
http://admin.rpmgarage.com/images/at...0.jpg?id=21036
Looks exactly the same as in an AUDM CL9 with NAV, except red backlit instead of white.
so it will only work with nav? if so can i buy the nav head unit and put it in my one? would the wiring loom be the same?
the only way you can get that to work is by installing the satnav unit
but would the sat nav work with the current wiring loom that i have? im driving an 04 base model
i did it and its a head ****. you use the same loom but you need to tap into some cables and youll need to add some cables
